Electrical diagram for a 1997 Shabah 180
Introductions
Old 07-07-2014, 08:32 PM   #1
Littledawg is currently offline
My Model: shabah 180
My Engine: 4.3 Aplha one
Send Littledawg:
Default Electrical diagram for a 1997 Shabah 180
Can anyone tell me where I can find a wiring diagram for a 1997 Mariah Shabah 180 with a 4.3 Alpha one. none of my lights are working anywhere on the boat I checked all the fuses and they are all fine:confusedi
  • Old 07-07-2014, 08:34 PM   #2
    Send Littledawg:
    Default Re: Electrical diagram for a 1997 Shabah 180
    sorry should of mentioned I do not have any operation manuals.
    Old 07-07-2014, 09:11 PM   #3
    First off, welcome aboard! Secondly, we do maintain a supply of electrical wiring diagrams, specific item manuals etc for contributing members and the boat owners manual is basically a general boating book and not boat specific. For your viewing pleasure i would suggest that you read the STICKYS located at the top of the Introductions forum. There is one regarding 'Where can i find a manual?" and another covering the benefits of being a contributing member.
    As for your electrical problems. 95% of the time such problems are caused by poor ground connections due to a bit of corrosion. I would suggest that you unhook your battery then remove & clean the connections at the fuse panel up underneath the drivers console as well as the grounding block on the transom behind your battery. Also remove & clean the small wires (both positive & negative) that are connected to your battery Then hook your battery back up and try them again.
    Old 07-09-2014, 02:46 PM   #4
    Send Littledawg:
    Thanks for the welcome and the info . I will check everything over Cheers !
    1995 Shabah Z212 Electrical Diagram Jeff W Original Mariah Talk 4 07-26-2017 02:11 AM
    Need electrical diagram for Jubilee Douglas Alderman Original Mariah Talk 1 04-13-2013 03:25 PM
    Diagram for 1997 209 donkingjr Original Mariah Talk 1 07-20-2012 02:41 PM
    wiring diagram for a '97 Shabah 180 jchemotti Boating 101 2 07-05-2011 09:44 PM
    Wanted: Electrical Wire Diagram (99 Jubilee) 214 Douglas Alderman Mariah Parts For Sale & Wanted 3 04-13-2008 05:22 AM
    There are 510 users
