My Introduction
Introductions
Old 04-04-2014, 01:36 PM   #11
Default Re: My Introduction
Originally Posted by RARinger View Post
The prop is fine, no vibration. We checked that. Apparently the branch just missed the outdrive and just hit the one wing of the Dolfin. Talk about a game of inches!
A damaged coupler (or bent prop shaft) will cause vibration but a loosened prop hub likely wont. The loose hub will cause the hub to spin faster than the prop but not transmit full power to it.
  • Old 04-04-2014, 10:15 PM   #12
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Evening Mikey
    Defo prop hub. If it's a rubber hub then even though it's spun you'll have trouble turning it by hand. If it's a flo-torq it'll just be trashed.....that's what they are there for.
    Anything else would have other results as listed above like noise, vibration or smell of rubber under the hatch
    Old 04-05-2014, 02:47 PM   #13
    RARinger's Avatar
    RARinger is currently offline
    My Model: Z209 Talari
    My Engine: 5.7 Mercruiser
    Send RARinger:
    How expensive/and how difficult is that to repair?
    Thank you so much for your insight.
    Is there a way that I can test for that with the boat being out of the water?
    I hope this isn't going to be a really expensive repair. I would love to get her back in the water this year. You have no idea how much I miss quality time with my Mariah.
    Old 04-05-2014, 03:02 PM   #14
    If its a rubber hub it will likely have to be pressed out and a new one pressed in but if its a Flo-Torq or a Michigan Wheel XHS style then its very easy to change. Maybe $75 for the rubber style and $50 for the Flo-Torq/XHS style.
    Again, i'll suggest that if you have a buddy with a similar outdrive/prop then borrow his and try it to see if it makes a difference.
    Andy b likes this.
    Old 04-06-2014, 02:27 PM   #15
    RARinger's Avatar
    Send RARinger:
    UNfortunately I don't. Where I go boating, it's mostly ski boats or pontoon boats. I think I've only ever seen one other Mariah on the whole river.
    How do I identify which one mine is?
    Also, according to the Smart Tabs video, my boat is too big. Does that matter? They sure seem like a great idea.
    Old 04-06-2014, 02:34 PM   #16
    Ohh they make them for your Z209 RA.
    Smart Tabs SX Trim Tabs
    Also have the stainlees steel ones if you want
    http://www.nauticusinc.com/smart_tab..._trim_tabs.htm
    Old 04-06-2014, 03:00 PM   #17
    This isn't hard.....really. Here's a link to a You-Tube video showing what a spun rubber prop hub looks like vs a good one. And here's a link to a Flo-Torq hub kit. You should be able to easily see the difference between the two styles and note that the Flo-Torq (or Michigan Wheel XHS) system is MUCH better as it makes things very easy to fix yourself.
    You also might want to take a couple of minutes and read my STICKY in the Prop Talk section for some insight on props.
    Old 04-07-2014, 12:30 PM   #18
    RARinger's Avatar
    Send RARinger:
    Thank you for a fantastic reply. I'm very appreciative of your help and your patience. I figured that the prop probably isn't ideally suited to the boat, but the previous owner put it on and they're expensive to replace. One thing's for sure, she jumps out on plane in a hurry.
    It occurred to me that the gas has been in the tanks since 2007 and probably isn't a good thing to run through the engine. Is there a way to drain it out other than a siphon? I believe that the tank is also aluminum, so corrosion shouldn't be a concern, correct?
    Does Mariah feature a drain for the tanks? If so, how do I access it?
    1996 z209 talari
    Introduction Van Introductions 2 04-14-2012 02:02 AM
    introduction petliz Introductions 4 05-24-2011 08:49 PM
    Introduction rlyoung Introductions 2 05-24-2011 08:44 PM
    Introduction Lots to learn Introductions 4 07-08-2009 09:17 PM
    Introduction ronbeco13 Introductions 2 09-19-2007 12:38 AM
    There are 208 users
