Hey there!
Introductions
Old 03-20-2014, 12:19 PM   #11
mattjkerns is currently offline
My Model: Diablo
My Engine: 4.3 L Mercruiser
Send mattjkerns:
Default Re: Hey there!
Where exactly is this crank? On the front of the motor but ... I'm confused
Sent from my XT907 using Tapatalk
  • Old 03-20-2014, 01:07 PM   #12
    Bottom pulley on engine. There is a center bolt , that is the one you need to try and see if you can turn the engine with.
    Usually a 1/2" drive ratchet and short extension with the socket will do the trick.
    Old 03-20-2014, 01:09 PM   #13
    My Model: Diablo
    Send mattjkerns:
    i just tried that. i was scared to go to hard, but when i did, nothing. either way. does it matter which way i turn? clockwise vs counter? i heard i could take spark plugs out and spray lubricant in there and let sit for 24 hrs?
    Old 03-20-2014, 01:17 PM   #14
    If you can't turn it , it's locked up.
    PB Blaster or WD40 in the sparkplug holes might loosen it up , but the damage is already done to the cylinders , rings , valves , etc.
    I'm afraid your looking at a new engine Matt.
    You can pick up a long block on Ebay for around the 2 grand you spoke of eariler , but you need to have the exhaust manifolds pressure tested to make sure they are OK.
    mattjkerns (03-20-2014)
    Old 03-20-2014, 01:19 PM   #15
    My Model: Diablo
    Send mattjkerns:
    ohh boy. not good news. thanks for all of the info, you have been a great help!
    Old 03-20-2014, 01:22 PM   #16
    Look at it this way Matt...........she run like a dream with that new engine , and be a lot more reliable too.
    4.3 , 4.3l , diablo , engine , mercruiser , motor , problems , replace
    There are 386 users
