| ShabahZ280 |
06-11-2013 05:43 PM |
Re: Texas Doc
This is a fairly common problem, it's been brought up many times on the forum. I'd be willing to bet there's nothing wrong with your transducer, it's just come unmounted from the epoxy in the hull. The transducer is a round black "hockey puck" under the engine. If you can locate it, and it moves around, that's your problem. You'll just need to get some SLOW CURE epoxy (not the 5 minute type), sand down the existing stuff, and remount it. That's the quick explanation, use the search function up top to search for "transducer" and you'll find lots of people's experiences and advice.
