Hi to all from England
Introductions
Old 09-02-2012, 01:07 PM   #1
paulcj77's Avatar
paulcj77 is currently offline
My Model: 180 shaba ltd
My Engine: 2012 merc 4.3 mpi
Send paulcj77:
Default Hi to all from England
Have just purchased a '97 - 18' Shabah for a cheap price as the mercruiser 4.3 has seen better days.Because the condition of the boat is like new I've decided to have a brand new 4.3 mercruiser fitted,so can anyone advise me on 4 bbl carb or go mpi .Allso what sort of preformance I'll get and advice on prop size.
Thanks.
Paul.
  • Old 09-02-2012, 02:11 PM   #2
    Default Re: Hi to all from England
    Welcome aboard Paul. I have a '96 with the 4bbl carb 4.3LX and while it starts okay it would be much nicer to have the mpi version. The other issue you may run into is that the carbed versions run with a 1.81 gear ratio while the mpi uses a 1.62 gear ratio so you may have to consider changing out the gears with the newer motor.
    As for the prop, most members here run either a 19" pitch 3 blade or a 20" pitch 4 blade to keep the WOT rpms within the recommended 4400-4800 range. Performance wise you should hit the high 40's with a fresh engine & prop.
    When you have a moment, check out our Member Map and take the time to 'pin' your location?
    Old 09-02-2012, 03:50 PM   #3
    Welcome to MOC Paul. Nice find on your Shabah.
    I too thought about a MPI setup not to long ago. I decided against it about the time I saw the 7500.00 price tag for complete motor package! And like mikey said your going to have to do a gear change in order to reap the full benefits. So add another 1000.00 to that.
    You might be able to go with the TKS motor for easier starts. I don't have any experience with them at all , but some of the members do I'm sure!
    Once again , Welcome!!
    Larry
    Old 09-04-2012, 08:48 PM   #4
    paulcj77's Avatar
    Send paulcj77:
    Thank for the info guys,going to go for the mpi my mechanic seems to think I have the right gear ratio.
    Unfortunateatly it's not marked on my upper unit so will need to work it out another way,our summer (not that we got much of one this year) is all most over so if that gears need changing too I've got till next year to save again.
    to get it sorted.
    Thanks again
    Paul
    Old 09-04-2012, 10:59 PM   #5
    Have a look at this link for locating either of the markings for the outdrive gear ratio.
    paulcj77 likes this.
    The Following 2 Users Say Thank You to mikeyt For This Useful Post:
    paulcj77 (09-04-2012), V-side-down (09-07-2012)
    Old 09-23-2012, 04:01 PM   #6
    paulcj77's Avatar
    Send paulcj77:
    Just an up date on the above,Now the new 4.3 mpi fitted and ran in for 11hours and loving it.
    Although I could do with some more advice about the gear ratio,I'm running on the 1 .81 as with your advice
    I confirmed,With a 21 pitch prop I'm getting 47 mph at wot 5100 rpm ( bit high I know only done this
    once and briefly) if I change the gearing to 1.61 how will this affect performance and what
    Other benefits will this effect .
    Thanks again for your help
    Paul.
    Mariah in England mikeyt Chit Chat/Off-Topic 5 07-16-2014 01:09 PM
    Selling my 182 Shabah (New England) bbrophy58 Mariah Boats For Sale & Wanted 0 08-22-2012 12:04 AM
    Hi from England Paul R Introductions 3 04-14-2009 06:20 AM
    Total Threads: 13,324
    There are 425 users
