Just bought my first Mariah
Introductions
Old 07-11-2012, 02:02 PM   #11
Reflex is currently offline
My Model: Barchetta
My Engine: 4.3L
Send Reflex:
Default Re: Just bought my first Mariah
ok thats pretty much what i was thinking about the glass. thanks!
Last night was pretty fruitful. Pulled the thermostat and water pump. Flushed the block. Replaced the freeze plugs. There was some rust inside the water jacket near the bottom of the block. But after flushing water made it to all outlets easily. I dunno a whole lot about boats but i kinda figure for a 94 block that has been in and out of the water on and open cooling system the rust is probably pretty normal.
Got it all back together with new gaskets and installed the new manifolds and risers. next is a carb rebuild kit and new trim cylinders. the trim cylinders work great but the hoses on the outside are shot. So either new hoses or all new cylinders.
  • Old 07-13-2012, 04:44 AM   #12
    My Model: Barchetta
    My Engine: 4.3L
    Send Reflex:
    Tonight was the muff test. Hooked up The muffs and ran the engine for about 15-20 min. First time running with water flowing Through the whole system. No leaks and no water in the oil!
    Installed new stero headunit and surround. Stero works great! As long as weather permits saturday will be her first day on the water! Very excited!
    Old 07-13-2012, 11:39 AM   #13
    Slick02 is currently offline
    My Model: Z210 Talari
    My Engine: 5.0 Gen2 Alpha
    Send Slick02:
    Reflex,,congrats on the good fortune,,,same thing happened on my end, (got the boat almost 3 weeks ago and still haven't had it in the water) got everything working, new impeller and new thermostat boat ran great on the hose for about 20 minutes but waiting on my bimini to come in before I lay out and change the head unit bought a new JVC hoping the wiring plugs would be the same(but we know that aint gonna happen) good luck on your lake test Saturday (doing mine Sunday.)
    Old 07-13-2012, 01:50 PM   #14
    My Model: Barchetta
    My Engine: 4.3L
    Send Reflex:
    Yeah. I also installed a new jvc. Plugs were different. Since its a boat and you can't ground to anything like a car. They loop the grounds for the speakers. So you will not use every speaker ground wire like you do in a car. It's pretty simple to figure out once you get in there.
    Thank you Reflex for this useful post!
    Slick02 (07-13-2012)
    just bought my Mariah pod Introductions 3 06-17-2011 12:17 AM
    Just bought a 96 Mariah 209 Luis Original Mariah Talk 2 05-29-2011 05:13 AM
    Can't beleive I bought a second Mariah! 300sflyer Original Mariah Talk 15 05-11-2009 04:35 AM
    Just Bought my Mariah MAJIC Introductions 1 06-01-2008 03:21 AM
    Just bought a well-loved Mariah... TedSzczepaniak Introductions 3 07-30-2007 05:21 PM
    There are 250 users
