Needing info on the Mariah boat
Introductions
Old 04-22-2012, 02:04 AM   #1
Dawnwax2 is currently offline
Send Dawnwax2:
Default Needing info on the Mariah boat
We are going to check out 2009 18.9 Mariah bow rider tomorrow..... So I have googled looking for the pros and cons of the boat. Nothing much is coming up except sea ray is the maker. Can anyone give some insight on the pros and cons? We are about to sign on the dotted line for a glasstron however we just found a good deal on the mariah. It would be appreciated if anyone could shed some light on the Mariah.
  • Old 04-22-2012, 04:44 AM   #2
    Default Re: Needing info on the Mariah boat
    Not sure where you got that info from but ..... 'Sea Ray' is not the maker of Mariah boats. 'Sea Fox' is the manufacturer. We have a couple of members here with that particular model but i dont see in reviews on it in our archives. The closest i can come is a 2009 R19.9 that will be somewhat similar.
    Old 04-22-2012, 12:09 PM   #3
    Minnox's Avatar
    Minnox is currently offline
    My Model: Z 235 Talari
    My Engine: 5.7L Bravo III
    Send Minnox:
    It is funny I was looking at a Glasstron and a Mariah at the same time! Well as you can probably tell the Mariah won. The Mariah was older but when I looked closely at both of them the Mariah was more solid and very well built with more options. For me the Mariah had a better feel and you you should always go with your gut...LoL
    Good Luck and if you get the Mariah post some pics.
    Mike
    1996 Z235 Talari 5.7L Bravo III
    Upper Chesapeake Bay Is My Playground!!!
    New member needing some help. DuAnne Introductions 1 10-20-2011 03:14 PM
    New Member needing help with Prop Breaman Prop Talk 4 02-16-2011 10:41 PM
    Boat info Chris182 Introductions 4 06-15-2009 03:01 AM
    need info on boat weight jsk9675 Original Mariah Talk 4 07-01-2008 04:29 PM
    Boat Info David Ward Original Mariah Talk 6 01-04-2008 05:37 AM
    There are 235 users
