-   -   1996 z200 (http://www.mariahownersclub.com/forum/introductions/6568-1996-z200.html)
rnrebel1 03-14-2012 02:29 AM
1996 z200
hello
I am from northern Il. I have the cover boat on the 1996 sales brochure the burgandy Z200 limited addition. I am restoring it, I have the interior completely revomed. I have some broken items the main piece I am looking for is the netrual safety button in the center of the throttle and the accoridan boot for the steering column. I believe these are the two things that make this project comtlete, and if some one knows how two seperate the throttle I could use some smoe pointers.
DCB_MINDED 03-14-2012 02:37 AM
Re: 1996 z200
Im not sure if these are the same, or if what you need is sold, but there are a bunch of parts from an 01 here:
http://www.mariahownersclub.com/foru...bah-202-a.html
Im sure one of the experts will chime in with more details.
rayzorback 03-14-2012 03:24 AM
Re: 1996 z200
Welcome, and I'm no expert, but I did finally get my throttle handle separated. There is a screw on the back of the handle that must be removed (Half way there) On the lower right of the handle, there is a plastic tab that needs to be depressed somehow (I broke mine). I then screwed the side panel together after my repair. Hope this makes some sense. Maybe someone here can help clarify.
