179 Talari
Introductions
Old 07-25-2011, 11:09 PM   #1
Uncle Bear is currently offline
My Model: 1998 180 SE Talari
My Engine: 4.3 merc
Send Uncle Bear:
Default 179 Talari
Hi everyone, been some time away from boating, got boat out yesterday. Speedoo and gas gauge not working. Gas gauge when full is bouncing around and Speedo not working however RPM gauge is --- Any thoughts to fix this would be appriciated. THXS
Uncle Bear
  • Old 07-25-2011, 11:42 PM   #2
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    Default Re: 179 Talari
    Well speedo is usually just plugged I tend to disconnect it from back of speedo under dash and blow it out back wards it might just be something in the opening on the outdrive, you could pop out quickly though worth taking a alook first since it has been sitting. Gas sounds like a sticky float if not its the sending unit would be my guess.
    darkcalling
    Z 278 Limited
    Old 07-26-2011, 02:03 AM   #3
    Blind32 is currently offline
    My Year: 2007
    My Model: SX19
    My Engine: 3.0L MerCruiser
    Send Blind32:
    The gas gauge might be a bad ground. Make sure it is grounded good and not corroded
    Mark
    2007 SX19
    Dallas TX
    Old 07-28-2011, 05:33 AM   #4
    My Engine: 4.3 merc
    Send Uncle Bear:
    Thanks everbody. My leg was plugged with a small piece of wood , which I drilled out and I cleaned the ground on the top of the gas tank, if that doesn't work I will try to remove the float and see what is going on. Thanks again for all the help.
    Uncle Bear
    Difference between 240 Talari & 240 Z Talari ? wunn Original Mariah Talk 3 07-03-2009 03:03 PM
    There are 299 users
