1996 shabah 180 electric wiring diagram
Introductions
Old 06-28-2011, 01:18 PM   #1
frenchman_9 is currently offline
My Model: 180 shabah
My Engine: 4.3/v6 alpha one
Send frenchman_9:
Talking 1996 shabah 180 electric wiring diagram
Hi there, ive recently purchased a 1996 shabah 180. The red/green nav lights stopped working and the tail light too. i would like to fix it so i can continue cruising at night, without any issues.
If anyone can help i would appreciate
  • Old 06-28-2011, 05:02 PM   #2
    Default Re: 1996 shabah 180 electric wiring diagram
    First thing to check is the connections. Corrosion is a real problem.
    Old 06-28-2011, 07:43 PM   #3
    Slash9point5's Avatar
    My Model: Barchetta 182
    Send Slash9point5:
    If that does not work, next I would check the switch and fuses. Seeing as they both are not working, it would lend itself to a common issue.
    Checking would include investigating for:
    *corrosion at the connections to the fuses (the most typical problem)
    *corrosion at the wires around the fuses and the switch
    *proper operation of the switch (using a mutlimeter or test light)
    Good luck,
    Kris
    Wiring Diagram wanted blank one Sea Fox - Mariah Talk 0 06-08-2011 03:46 AM
    need wiring diagram sweetwilyum Introductions 2 05-26-2011 02:59 PM
    I need a wiring diagram for a 94 Shabah 212z Jbetschart Original Mariah Talk 1 01-04-2010 08:27 AM
    Wiring diagram wanted MariahMan Sea Fox - Mariah Talk 0 12-27-2009 04:53 AM
    Wiring Diagram bakdraft Sea Fox - Mariah Talk 17 06-26-2009 01:56 AM
    There are 216 users
