2007 sx21
Introductions
Old 06-21-2011, 05:54 PM   #1
MJL529's Avatar
MJL529 is currently offline
My Year: 2007
My Model: SX21
My Engine: 5.0 Alpha I
Send MJL529:
Default 2007 sx21
Just bought a new SX21 (2007) and appears that WOT MPH is about 40 MPH with 5.0 mercruiser and alpha 1 drive. Wondering if that should be about 10 MPH faster based on what I can read? Not sure of the prop size/pitch as boat is down at lake-will look this weekend
What is the best cruising RPM to not overwork the engine?
  • Old 06-21-2011, 07:48 PM   #2
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    Default Re: 2007 sx21
    I would suggest checking rpms at wot to see if you are maxed out you should be revving about 4500-4700 rpm stock to stay in the safe range and is that speed from gps or the boats speedo?
    darkcalling
    Z 278 Limited
    Old 06-21-2011, 10:15 PM   #3
    Yes you should be up in the mid-high 40's in that boat. Check out what prop is on it first and if you have an opportunity check the rpms at WOT. Being down around 40mph makes me think its either badly propped or in need of a tuneup. Let us know what you find?
    Old 07-11-2011, 09:05 PM   #4
    MJL529's Avatar
    My Year: 2007
    My Model: SX21
    Send MJL529:
    Might have been some bad gas (bought it with small amount of gas which have been from last year). Boat is running closer to 48-50 mph when trimmed up slightly. Thanks for the replies from both of you
    Sx21 Manual IANTODD Introductions 4 06-14-2019 12:41 PM
    2007 SX21 Bimini/swim MJL529 Introductions 0 06-11-2011 12:28 PM
    considering 2008 SX21 jjjs Sea Fox - Mariah Talk 6 07-15-2010 01:51 AM
    windshield for SX21 flood Introductions 1 08-05-2009 01:58 AM
    There are 298 users
