1998 Mariah Question
Introductions
Old 08-10-2010, 04:08 AM   #1
Serenity205 is currently offline
My Model: 205 Shabah
My Engine: 351 Apha 1 5.0
Send Serenity205:
Default 1998 Mariah Question
My 1998 205 Shabah runs perfect, but I felt somewhat ignorant when I was told at a local boat shop to have the mercruiser impeller changed every two years. ( I had no idea it had one) I was assuming the 305 Chevy has a water pump. The boat never overheats and is used in fresh water exclusively. Post from Irvine, CA USA
  • Old 08-10-2010, 04:31 AM   #2
    Nathan5678 is currently offline
    My Model: Shabah 180 LE
    My Engine: 4.3l alpha
    Gallery Images: 8
    Send Nathan5678:
    Default Re: 1998 Mariah Question
    The engine does have a water pump but there is also a plastic impeller in the lower outdrive the draws water up to the engine. It's good to have it changed if you are not sure how long it's been since it was last replaced. Not sure about every 2 years but it good insurance to replace it on a regular schedule.
    Nathan J
    Old 08-10-2010, 03:12 PM   #3
    Agreed. Personally i think every 2 yrs is overdoing it but it depends on how much you use the boat and what conditions the boat is operated in. I plan on doing mine this fall and that will be 4 yrs for me but then i dont spend a lot of time on the water.
    Old 08-10-2010, 03:13 PM   #4
    Send Serenity205:
    Thank you . I will have it replaced this week.
    Old 08-11-2010, 07:10 PM   #5
    X2 on having it replaced. I bought my boat in January in Maryland, sea trialed in the Chesapeake Bay with skim ice. When I brought my boat back home, and launched it in May for my "Christening" in local waters, the impeller went bad, overheated the engine, and I had to be towed back in by a 14ft aluminum fishing boat. Not the greatest feeling.
    So I replace my impeller every 2 years, and even keep a spare onboard just in case.
    Old 08-11-2010, 11:32 PM   #6
    I guess the positive out of that experience is that at least it wasn't a Bayliner towing you home....
    Old 08-12-2010, 12:25 PM   #7
    95gts's Avatar
    95gts is currently offline
    My Model: Shabah 182
    My Engine: 3.0L
    Gallery Images: 4
    Send 95gts:
    I recently bought my '98 with 200 hrs on it, the impeller had never been changed by the previous owner (my father) so I dropped the lower unit this spring and replace it. The original looked fine, it didn't even have any cracking in the rubber. This is a freshwater only boat, I don't think i'll be changing it any more often than every 5 years or so.
    Old 08-12-2010, 03:07 PM   #8
    kevo is currently offline
    My Model: 180 Shabah
    Send kevo:
    Thanks for the info. What about my Shabah 180 with the mercruiser? I'm assuming it's the same? What should I expect to pay for something like this?
    Old 08-12-2010, 03:11 PM   #9
    95gts's Avatar
    My Engine: 3.0L
    Gallery Images: 4
    Send 95gts:
    It's also got the Mercruiser Alpha One Gen II outdrive.. I don't know what you'd pay to have the impeller replaced, but I paid $45 for the Quicksilver impeller kit and $8 a quart for the Quicksilver gear oil when I did mine.. It took me about 3 hours to do, i'd imagine a shop would be ALOT quicker.
    Thank you 95gts for this useful post!
    kevo (08-12-2010)
    1998 Mariah Z 255 for sale chadh Mariah Boats For Sale & Wanted 1 08-12-2010 03:38 PM
    Canada: 1998 Mariah 260 Bill Mariah Boats For Sale & Wanted 5 02-26-2010 08:20 AM
    Mariah 1998 Z255 chadh Mariah Boats For Sale & Wanted 1 12-16-2009 05:07 PM
    1998 Mariah 280z ???? 235guy Original Mariah Talk 6 09-21-2009 02:57 PM
    There are 348 users
