-   -   Boat info (http://www.mariahownersclub.com/forum/introductions/2723-boat-info.html)
Chris182 06-13-2009 03:17 AM
Boat info
I just bought the boat last yr, not to much info on it,,I have a boat lift for it rated for 2600 lbs,,can anyone tell me the weight of my boat,,
1994 Barchetta 182..it's a V6,,180 hp.
Cheers
WetWilly 06-13-2009 06:50 AM
Re: Boat info
Cheers
Hi Chris and welcome to the club!
Your '94 182 Barchetta weighs in at approximately 2430lbs with the 4.3L v6
Go ahead, click here and read this post, it will explain how to access the brochures that have the specs on all the models along with a lot of other important information!
Chris182 06-15-2009 02:19 AM
Re: Boat info
Thanks WetWilly...feel better now I know the boat lift will be safe..
Cheers
WetWilly 06-15-2009 02:33 AM
Re: Boat info
Hi Chris,
No problem, don't forget you'll need to figure out the amount of gas plus any gear stowed in your Mariah for the total weight (each gallon of gas weighs a little over 6LBS so a 1/2 tank would weight about 90LBS).
So you can see how fast the weight adds up so it wouldn't take much to equal the limit of your lift. :eek_animated:
Chris182 06-15-2009 03:01 AM
Re: Boat info
I know I'm really pushing the limit with the boat lift,,I've been in contact with the mfg. and there are a few things i can do to increase the weight cap. of the lift..
thanks for the help..only been on here for a few day and WOW ,tons of info on here..
