-   -   Hello all Mariah capitaine (http://www.mariahownersclub.com/forum/introductions/1885-hello-all-mariah-capitaine.html)
MMarko 11-06-2008 03:05 PM
Hi,
My name is Michel and Im Belgian , I have opportunity to buy a Z216 year 1998 , and may be you can help me to tell me certains info about this boat , i need what to look this boat has any default any help will be nice......thank you.....
Sorry for my english !!!!!
Regards.....
WetWilly 11-06-2008 04:47 PM
Hello MMarko,
Welcome to the club!
As far as I know, there is not any known problems with this model. Mariahs are one of the best built boats out there but any boat can have issues if the previous owners did not take care of them.
It would help if you could tell us what size motor and model of outdrive it has.
Do you have any have any information on this Mariah's history, maintenance records, what type of water it was used in (fresh or salt water?), previous repairs and thing like that?
If you are not familiar with checking boats and their equipment out, I strongly suggest to seek professional assistance in your area.
Good luck,
mikeyt 11-07-2008 02:40 AM
Originally Posted by MMarko (Post 11072)
Hi,
Regards.....
Welcome aboard Michel! We have at least one other member (Il Mio) who is also from Belgium (near Brugge) and i've been there a few times with my wife, who is employed by a Belgian company. As WetWilly says, Mariah's were 'over-built' in some regards and rarely suffer from poor construction but if the previous owners haven't taken care of it, there can be problems such as electrical glitches. Fortunately there are only a few items (trim, glass & interior seating) that are difficult to find but with the large number of members here, we are always learning how to overcome those problems. Feel free to post whatever concerns you have and we'll do our best to help you out.
MMarko 11-07-2008 08:09 AM
Z216 info
Hi,
Thank you for your fast answer....
Info about the boat.... the engine is 5.7l with 250 hours the drive is Alpha one and use in majority in salt water, I look the hull no damaged the engine start directly it's look ok no blue smoke.... the owner told the Rev of engine not working and the brake of trailer need to repair....
Thank you for your help...
Regards,
Tom 11-07-2008 09:45 AM
Welcome
Bienvenue!
il_Mio 11-07-2008 03:14 PM
Welcome MMarko,
I am glad we have another Mariah lover joining from our small country.
Cheers,
Johan
mikeyt 11-07-2008 05:06 PM
Originally Posted by MMarko (Post 11086)
Hi,
Regards,
By the 'Rev of engine' i'm assuming you mean the tachometer. Generally that problem is a corrosion issue. You should have access to the back of your instrument panel. On the back of the tachometer you will find a small black dial which should be set at '8 cyl'. Take that dial and spin in around a few times back & forth then reset it at the '8 cyl' and see if that doesnt cure the problem. Also check to make sure the wire connections on the tach are not corroded from the salt water use.
MMarko 12-12-2008 08:59 AM
Thank's
Hi,
Thank you for your welcome.
Regards,
