1996 Z255 Shabah Fuel Tank Specs
Introductions
Old 07-24-2023, 05:55 PM   #1
Thecasazza's Avatar
Thecasazza is currently offline
My Model: Z255 Shabah Limited
My Engine: 7.4L Gen 6 Bravo 3
Send Thecasazza:
Default 1996 Z255 Shabah Fuel Tank Specs
Hello people, I have a 1996 Z255 Shabah, the fuel gauge is not working , the float is defective, What are the dimensions and specs of the fuel tank and electronics, if any one knows.
Please & Thank you…,
  • Old 07-24-2023, 08:22 PM   #2
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Default Re: 1996 Z255 Shabah Fuel Tank Specs
    do a search on the forum to see if anyone has posted that information. There is no specific data on the original tank size in the files. You may also want to post the question on the facebook sites too.
    Thecasazza likes this.
    Thank you GregT for this useful post!
    Thecasazza (07-25-2023)
    Old 07-28-2023, 11:52 PM   #3
    Its most likely a faulty fuel sender unit at the tank and they are easy to replace with a universal unit. If i remember right (when i replaced mine about 7 yrs ago) you could trim the sender unit float arm to the correct length and there were instructions included showing you how to measure the depth of the fuel tank (thru the sender unit opening) and calculate what length the arm needed to be. When i replaced mine i did it as a set (new gauge & new sender unit) so that i had matching ohm resistance (240 - 33 ohm). Failing that, I'm almost certain there are more than a few You Tube videos on doing that work. btw.. your fuel tank capacity is 85 gals / 322 litres.
    GregT and Thecasazza like this.
    Thecasazza (07-31-2023)
    Old 05-28-2024, 05:49 PM   #4
    Thecasazza's Avatar
    Send Thecasazza:
    So just to recap... I first disconnected the sender wring and tested it to see the fuel gauge go to max, then I ended up taking off the fuel sender assembly and measuring the depth of the fuel tank, it is 13-3/4" deep. So I ordered a new sender unit from amazon the kind that is a straight pole with a floating donut, resistance is the standard 33-240ohms. works perfectly for only $35 CDN.
    Old 05-29-2024, 12:16 PM   #5
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Thanks for the update! Glad you found a solution.
    Member Boat For Sale: F/S 1996 Mariah Shabah Z255 tpdtopcop Mariah Boats For Sale & Wanted 3 11-14-2019 05:34 PM
    How do I empty the fuel tank on a 1996 Shabah 180? newbie Original Mariah Talk 4 04-25-2016 12:31 AM
    Sold: 1996 Mariah Shabah z255 NogginDoc Mariah Boats For Sale & Wanted 11 08-28-2015 09:12 PM
    1996 190 Shabah specs Big Kahuna Introductions 2 06-27-2013 05:38 PM
    need fuel tank part # for 1996 Shebah 18 eroc37 Original Mariah Talk 0 05-17-2011 07:09 PM
    There are 253 users
