Hello
Introductions
Old 07-10-2023, 09:28 PM   #1
khelly29 is currently offline
My Year: 1991
Send khelly29:
Default Hello
Hello,
I am trying to locate some bellows that I have been told are impossible to find.
My grandma owns a 1991 18ft inboard Mariah and needs to replace the bellows. I am being told because of the year this will be impossible as this year/model was only made for 4 years.
Does anyone have any suggestions on where I can find parts for this boat?
Thank you in advance,
kelly
  • Old 07-11-2023, 12:15 AM   #2
    Sparks&Stripes is currently offline
    My Model: Jubilee Z244
    My Engine: 350 Mag Alpha One
    Send Sparks&Stripes:
    Default Re: Hello
    Kelly, Bellows are not specific to a Mariah model. You need to know what kind of motor is in the boat. It will likely be a Mercruiser, Volvo, or yahama inboard motor, odds are Mercruiser. If Mercruiser you will need to figure out what outdrive is on the boat. It would be an alpha one or a bravo, both of which will have readily available parts. If it’s a Yamaha it might be tough, but nothing is impossible! Good luck!
    GregT likes this.
    Dan
    Upstate NY
    98 Mariah Jubilee Z244 - 350 Mag MPI/Alpha1G2
    88 Seebold Eagle 21 Closed Bow - 175 Suzuki OB
    97 Celebrity 240 Cuddy - 7.4 Merc/Bravo1
    88 Larson Delta Conic 250 Aft Cabin - 5.7 Merc/Alpha1G1
    86 Thompson Open Bow - 3.0 Merc/AlphaG1
    Old 07-11-2023, 12:27 PM   #3
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Default Re: Hello
    Hi Kelly,
    What Dan said, the bellows are pretty common. We could help a bit more if you can post a picture of the outdrive to narrow it down. Changing out bellows is not super difficult, but it is not really easy either. If you or someone else have not worked on outdrives before, you may want to check with a few local marine repair shops for an estimate. Paying a shop may be worth it.
    There are 359 users
