New Owner Issues
Introductions
Old 05-10-2023, 03:19 PM   #1
Bolmach1 is currently offline
My Year: 2006
My Model: SX19
My Engine: 3.0 Mercruiser
Send Bolmach1:
Default New Owner Issues
Hi Everyone,
I just bought a 2006 sx19 from a dealer as my first boat. I took it out a couple of times with no issues. The third time it wouldn’t go over 5 mph. I was told I had a spun prop. I replaced it with the exact OEM prop that was on it. When I went to take it out again. It wouldn’t start. I get a beep when I turn the key on but nothing happens when I turn it all the way to start it. The battery is fully charged. I made sure it was in neutral. I jiggled the key and tried moving the throttle. Nothing happened. Any help would be appreciated.
Bolmach1
  • Old 05-10-2023, 05:47 PM   #2
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Default Re: New Owner Issues
    Do you have the kill switch with lanyard on your model? Those can fail or move just enough to kill the ignition.
    Old 05-10-2023, 06:41 PM   #3
    My Year: 2006
    My Model: SX19
    Send Bolmach1:
    I tried bypassing the switch. Still nothing.
    Old 05-11-2023, 01:33 PM   #4
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    When you say it won't start do you mean it won't crank or it cranks but does not fire?
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-11-2023, 03:02 PM   #5
    My Year: 2006
    My Model: SX19
    Send Bolmach1:
    I won’t crank.
    Old 05-11-2023, 03:13 PM   #6
    My Model: Z280
    Most common issues are the neutral safety switch in the throttle and the save solenoid.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-11-2023, 03:18 PM   #7
    My Model: Z280
    Start signal from key switch runs through neutral safety switch, then thru large connector on engine to slave solenoid which feeds the solenoid on the starter. If you have a voltmeter or test light, trace the start signal.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Bolmach1 (05-11-2023)
    Old 05-16-2023, 03:03 PM   #8
    My Year: 2006
    My Model: SX19
    Send Bolmach1:
    Ignition switch is good. The kill switch is good. Neutral safety switch is good. Starter is good. I checked all the fuses and none were blown. Cleaned all connections on the battery. Checked the wiring harness connections, also. They look fine. The only thing not done is the slave relay. I can't find it. I tried to Can anyone tell me exactly where it is? I tried tracing the yellow/red wire but it went into a harness.
    Old 05-16-2023, 03:19 PM   #9
    My Model: Z280
    It is usually located on the top of the motor, near the back. Usually close to the large plug. Pretty small, less than 2 inch diameter solenoid.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-17-2023, 05:35 PM   #10
    My Year: 2006
    My Model: SX19
    Send Bolmach1:
    Turns out it is a bad starter. The solenoid was frozen.
    Thanks everyone for your help.
    fuel issues Tatham007 Original Mariah Talk 2 04-24-2014 12:04 AM
    Another SX owner with headrest issues AndyFL Sea Fox - Mariah Talk 11 02-06-2013 11:58 PM
    Alternator issues? bnussbaum Original Mariah Talk 5 06-05-2011 03:02 AM
    98 242 Z Nav light issues DRTutt Original Mariah Talk 2 05-10-2010 05:39 PM
    New Mariah Owner With Nav Light Issues MariahShabah3.0 Original Mariah Talk 4 08-24-2007 04:45 PM
    There are 389 users
