Engine Trouble
Introductions
Old 06-21-2022, 01:02 PM   #1
brettcab is currently offline
My Model: C211 Talari
My Engine: 5.7 Liter
Send brettcab:
Default Engine Trouble
I'm a new member here. I have enjoyed my 1997 C211 Talari since purchasing it in 2007. I'd had trouble with the starter last year, after replacing the battery but I made it through the season. This year it wouldn't start so after charging the battery and I even replaced the starter it still doesn't start. I get the normal tone when I turn the key on but only hear a click from engine compartment. I tried holding key in start position for 2-3 seconds and multiple attempts, but nothing more happens. I've checked the kill switch and that it's in neutral.
  • Old 06-21-2022, 04:56 PM   #2
    Lancer is currently offline
    My Year: 2003
    My Model: Z 235 Devanti
    My Engine: 7.4 Bravo 1
    Send Lancer:
    Default Re: Engine Trouble
    clean every connection so they are shiny enough to eat on, especially the grounds. make sure your battery has around 13 volts or more.
    Old 06-21-2022, 05:13 PM   #3
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Does your engine have a starter solenoid, maybe integrated with the starter itself? If you replaced both the starter and battery, the solenoid may be bad if it isn't part of the new starter. I'm not sure what you have there.
    and double check all connections as suggested too.
    Old 06-23-2022, 12:33 PM   #4
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Check the slave solenoid usually located on the top of the engine near the red reset button. It receives the start signal from the keyswitch and relays a it to the solenoid on the starter. If the internal contacts on the slave solenoid are carboned up it will not pass enough current to engage the solenoid on the starter.
    GregT and brettcab like this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 07-11-2024, 10:08 PM   #5
    Send brettcab:
    I gave up on the boat for awhile as nothing helped. I've had a couple mechanics look at it this year. I just replaced the slave solenoid and reset switch. The starter is new from a couple years ago but I'm not sure I connected all the wires correctly. I've searched for a wire diagram specifically for my boat with no luck. Perhaps if I can make sure it's wired up right I'll know more. Any suggestions?
    Old 07-15-2024, 12:56 PM   #6
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Just a thought because I was in a similar situation with the "click" only sound - does your motor rotate freely? It didn't freeze and lock up like mine did I hope.
    Check your ground cables too, make sure they are tight on the engine block end.
    I'm not sure of the wiring setup and it's been along time since I messed with mine so I'd have to go look again. This might be a good question to ask on the facebook page to get a faster response.
    Ran into some trouble Mike S Original Mariah Talk 14 05-26-2009 06:05 PM
    Engine trouble grommett Original Mariah Talk 5 04-26-2009 09:09 PM
    Trim trouble shilo Sea Fox - Mariah Talk 5 02-20-2008 02:24 PM
    Having trouble with avatar shilo Introductions 3 01-27-2008 07:10 AM
    trim trouble aquaknot Original Mariah Talk 5 08-13-2007 12:17 PM
    There are 362 users
