need help
Introductions
Old 07-07-2008, 02:03 AM   #1
KICKASS is currently offline
My Model: 1995 180 talari 4.3l alpha 1
Send KICKASS:
Angry water in gas tank
i have a '95 talari 180 ani went and filled it up this weekend and it only took nine gallons. then it ran out of gas half way through the day. then i put filled it up again and it only took six gallons and wouldn't start. so i took a furl sample from the line right after the pump. and there was 50/50 gas and water in a 20 ounce bottle. has anyone had this problem.i have not looked in to it to much. but was woundering if any one had any ideas or a simular problem.
  • Old 07-07-2008, 04:03 AM   #2
    bdbyrnes's Avatar
    bdbyrnes is currently offline
    My Model: Talari z240
    My Engine: 7.4L V8 - Bravo III
    Gallery Images: 41
    Send bdbyrnes:
    With a handle like that it's hard to imagine you could need or 'want' any help.
    Did you try any fuel stabilizer? http://www.goldeagle.com/sta-bil/
    Brent
    1995 Talari Z240
    7.4L Merc, Bravo III Outdrive
    Corsa Performance Captains Call Exhaust
    Samson Sports Tower
    Old 07-17-2008, 08:42 PM   #3
    Hi KICKASS,
    Any luck removing the water out of your tank? I assume you'd have to get it pumped out and then use a water remover for the remaining stuff at the very bottom ("Iso-HEET" Premium Water Remover works great). This is what we had to do when we found water in our tank.
    Remember to use a fuel stabilizer whenever your not going to use your Mariah for a while. Here in California, our gas contains up to 10% ethanol and it just soaks up moisture if if sits around. I use "Sta-bil" brand fuel stabilizer.
    Good luck,
    There are 284 users
