Hello all!
Introductions
Old 08-08-2021, 03:13 PM   #1
Vegas is currently offline
My Model: 244 Jubilee db
My Engine: 5.7 bravo III
Send Vegas:
Default Hello all!
Greetings. I am a first time boat owner. I purchased a 98 Jubilee deck boat. I am in love!!
I do have a question. Does anyone have a picture of their dash with all of the switches and what they do?
All of mine have worn off and I am unsure of what they do. My horn does not work and side (red/green) lights don’t work so I am investigating that now.
Thank you for any help you can offer! Glad to be apart of this community!
Sean
  • Old 08-08-2021, 06:01 PM   #2
    Default Re: Hello all!
    Which model Jubilee do you have? Dashes varied depending on size.
    As for the horn / lights not working, that is usually a poor connection issue. I would suggest pulling the fuse first to see if its good. If it is cleaning the contacts in the fuse box (and the fuse) usually resolves the issue.
    Old 08-08-2021, 07:29 PM   #3
    Send Vegas:
    Yeah I’m trying to locate the fuses. I know the bulbs work after taking them out and hooking them up to a battery.
    The boat is a 98 Jubilee 24’ deck boat. Not the Z. I know that.
    Old 08-09-2021, 12:37 AM   #4
    I believe the fuse panel is behind the ceiling in the toilet area on the 244.
    Old 08-09-2021, 10:35 AM   #5
    Sparks&Stripes is currently offline
    My Model: Jubilee Z244
    My Engine: 350 Mag Alpha One
    Send Sparks&Stripes:
    You can pay the small fee on this site and download the wiring schematic for the boat. I have a 98 z244 jubilee and the fuse panel is located behind the radio bezel. Pain to get to because you need to pull that bezel out but make sure you clean all your contacts and fuses good. I had corrosion in mine and several things were not working until I cleaned them up. Most the accessory switches do not power anything if you have them, they are prewired to run aftermarket accessories should you choose to ad them. I would download the schematic and it will give you a good idea of what switches are what.
    Dan
    Upstate NY
    98 Mariah Jubilee Z244 - 350 Mag MPI/Alpha1G2
    88 Seebold Eagle 21 Closed Bow - 175 Suzuki OB
    97 Celebrity 240 Cuddy - 7.4 Merc/Bravo1
    88 Larson Delta Conic 250 Aft Cabin - 5.7 Merc/Alpha1G1
    86 Thompson Open Bow - 3.0 Merc/AlphaG1
    There are 253 users
