-   -   Prop Question (http://www.mariahownersclub.com/forum/introductions/13613-prop-question.html)
Her Boat 04-13-2021 07:10 PM
Prop Question
Hello all!
This is my first post. We are getting ready to summerize our Z255 Shabah and in need of a new prop. Looking for to get on plane fast no so much top end. The boat has the 7.4 motor. Not sure what drive it has the bravo 1 or 2? Any help identifying that would be appreciated also.
Motoxxx43 04-20-2021 04:04 PM
Re: Prop Question
Does it have one prop? Bravo 1
Does it have two props? Bravo 3
I'm unaware of there being a Bravo 2 on any Mariah.
You'll most likely end up with a prop needing a "hub kit". Your existing prop may have one on it now.
Not knowing what prop is on there now and how it performs would be difficult to tell you a prop part number that might work.
We need to know your RPM at wide open throttle, what prop you have and what elevation you are at to come up with a ballpark prop.
