Mrmuuzik
Introductions
Old 03-25-2021, 06:25 AM   #1
Mrmuuzik is currently offline
My Model: Z200 TALARI
My Engine: 5.0 alpha 1
Send Mrmuuzik:
Default Mrmuuzik
Need help please. Have a 1994 Talari 200z with 5.0 mercruiser. Took boat out ran fine to beach and back to dock. Took boat out 4 days later can’t get up on plane or past 2000 rpm at wot Revs high in neutral no power Under load . Changed cap , rotor, water fuel separator, new carb filter. Any ideas? Thank you In advance. Can please reply directly at [email protected] thank you.
  • Old 03-25-2021, 01:54 PM   #2
    Default Re: Mrmuuzik
    If you want private instruction you'll need to have a marine mechanic look at it. That 'service' isn't offered here on this site.
    Engine Won't Reach Operating RPM. Check the following;
    1. Fuel condition. Type and Octane, possibly old fuel
    2. Propeller hub slippage or damaged blades
    3. Engine timing and ignition system operation
    4. Restricted fuel pickup tube or anti siphon valve. Fuel System Test
    5. Restricted carburetor air intake (clogged flame arrestor)
    6. Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive
    7. Poor cylinder compression - Compression Test
    8. Carburetor defective. Dismantle and clean.
    9. Fuel pump pressure and vacuum
    10. Engine Overheating. Alarm should trigger.
    There are 261 users
