Light issue
Hello, Does anyone have any suggestions concerning the outer lights not working on my Mariah SC 23 2005? I imagine I should start with checking the fuse. However, I do not know where this is located. Thank you in advance.
Re: Light issue
I'm not exactly sure where the fuse panel is located on one of the SeaFox built Mariahs but it is likely up underneath the dash & mounted against the hull. Yes a fuse would be my first thing to check and then ensure that the ground wire is making clean contact.
| All times are GMT. The time now is 09:06 PM. |
