-   -   Z marine (http://www.mariahownersclub.com/forum/introductions/12853-z-marine.html)
bigzmarine 06-08-2020 02:20 PM
Z marine
I know there is no owners manual for my boat, but I am having a no spark issue with my 2008 sx 19 with a 4.3 I replaced the dist cap, rotor, coil, crank sensor, and harmonic balancer, still no spark, hoping to find a bad fuse, is the fuse box under the dash ? can't see it, everything else works, I have been boating for 30 years and have checked all the usual stuff, kill switch, netural safty switch, key etc, etc, ecu powers up fuel pump etc, help ! thanks
mikeyt 06-08-2020 02:37 PM
Re: Z marine
Read the STICKY entitled "Troubleshooting Your Starting System" in the General Maintenance section.
bigzmarine 06-08-2020 04:45 PM
Re: Z marine
thanks, but not a starter problem spark problem
Tlolesen 06-09-2020 10:44 AM
Re: Z marine
No Spark no Start.
Ifixmyown 06-09-2020 06:18 PM
Re: Z marine
You might not be able to find a manual for the boat but Merc manuals are readily available from Merc or I got mine thru emanual online. Also look at Merc Easy parts web for all your part numbers. https://public-mercurymarine.sysonli...=englangDB=eng
pole trick 06-10-2020 09:00 AM
Re: Z marine
It been awhile since I work on a thunderbolt ignition system and dont have manual in front of me.
Normally with key on you should have power to coil. How ever on mercury i/o there is oil pressure switch that cuts off fuel pump or ignition until it gets oil pressure. I don't remember how it all works.. could be oil pressure switch... trace power back from coil until you find problem
Ifixmyown 06-10-2020 12:52 PM
Re: Z marine
I dont know what version of Thunderbolt you have. If you email Merc with your engine serial number they will email back quickly with the wiring diagram.
