-   -   Engine stalls after running several minutes (http://www.mariahownersclub.com/forum/introductions/12848-engine-stalls-after-running-several-minutes.html)
godellsimmons 06-07-2020 05:59 PM
Hello,
I have a 1993 Mariah 2200Z and the boat runs great for several minutes (>30) and then stalls when idling or won't start after I shut it off. If I wait for several hours, the boat starts and runs fine. I'm thinking that maybe I have a vapor lock or the fuel tank vent is plugged? Any thoughts from anyone or does anyone know where I can buy a fuel tank filter for the boat?
George
I have a 350 cu in engine, 4 barrel carb, the engine temperature was normal. This happened late last season and again the first time out this year. I've owned the boat 4 years... prior to this, it has run great.
mikeyt 06-07-2020 06:20 PM
Re: Engine stalls after running several minutes
Might help if you said what engine you have. Check and replace the water/fuel filter if you haven't done so for a while. They are available at any marine supply shop such as West Marine. I'm inclined to think though that the problem is a failing/malfunctioning ignition coil that is overheating. Once it cools down, it will work again. Again an ignition coil would be available at places like West Marine.
godellsimmons 07-23-2020 01:58 AM
My Mariah has. 5.0L alpha one engine. After cruising for about 30 minutes, the engine stalls when going from cruising speed to idle. I have replaced the ignition coil and it still happens. Could the float be stuck on the carburetor?
Hudson River Steve 07-23-2020 11:30 AM
It could be many things.
Does it stall when shifting to neutral? If so I would start by looking at the ignition interrupt switch that is needed to get the Alpha one out of gear.
If it stalls when running at idle for a period of time either in or out of gear I would look at the carb.
