New/old Mariah Owner seeking info to repair gas gauge
Introductions
Old 06-21-2019, 06:11 PM   #1
meachele3 is currently offline
My Model: 182 Shabah
My Engine: 3.0L
Send meachele3:
Default New/old Mariah Owner seeking info to repair gas gauge
Just bought a 2000 182 and the only thing not working is the gas gauge. Anybody have any experience/info fixing one?
  • Old 06-21-2019, 08:10 PM   #2
    Default Re: New/old Mariah Owner seeking info to repair gas gauge
    Its probably the connection at the sender unit. Take the connections apart, clean thoroughly and re-attach. Also check that the connection is secure on the back of the gauge itself. IF that does not work, then it could be a failed sender unit. Access is generally right in front of the motor underneath a small 'flap' in the carpet.
    And just as a reminder, do not use power tools if you are replacing the sender unit. Potential sparks and gasoline fumes dont mix well.....
    Seeking info about 2001 Mariah Bnick Introductions 4 04-02-2018 02:37 AM
    New owner! Need some info from the pro's! Hunter12345 Introductions 23 04-30-2016 12:02 AM
    Info on threads pertaining to 2350z info erndog123 Original Mariah Talk 1 06-25-2012 12:20 AM
    Faria gauge repair issues DONNA General Maintenance 6 05-25-2010 02:02 AM
    New owner with some problems n(throttle,temp gauge,etc) jasfiveo Original Mariah Talk 2 05-20-2008 02:46 PM
    There are 448 users
