Stern drive stuck in up position
Introductions
Old 05-27-2019, 01:57 PM   #1
Thermos is currently offline
My Year: 1990
My Model: 2000xl
My Engine: 5.7 bravo
Send Thermos:
Default Stern drive stuck in up position
I’ve got a 1990 xl 2000 with 307 hours 5.7 Mercury alpha. The trim gets stuck in the up position from time to time . Ive used it for 1 hour. The remedy is the crack the line at either the cylinder ( when on the trailer) or near the pump (if on the water ) and it will drop. Thoughts? A buddy says it sounds like a stuck check valve?
  • Old 05-27-2019, 03:11 PM   #2
    Levinz11 is currently offline
    My Year: 2006
    My Model: SX20
    My Engine: 4.3 Alpha
    Send Levinz11:
    Default Re: Stern drive stuck in up position
    When you hit the down button what happens?
    Old 05-27-2019, 03:39 PM   #3
    My Year: 1990
    My Model: 2000xl
    Send Thermos:
    The motor wines. It makes a different sound when you press up.
    Old 05-27-2019, 03:49 PM   #4
    My Year: 2006
    My Model: SX20
    Send Levinz11:
    So the motor does indeed spin and it’s not a wire/switch/connection issue.
    I just put a complete trim pump assembly in my SX20. All my wiring and solenoids were pretty rough. It’s a plug and play swap. $300 on amazon.
    Stern drive will not rotate to right speco1959 Original Mariah Talk 6 07-01-2013 03:41 PM
    HELP/ Bravo III stuck in drive/ no neutral or reverse jasfiveo Original Mariah Talk 7 06-10-2012 04:30 PM
    leak in stern drive tem Original Mariah Talk 1 05-12-2011 08:30 PM
    Stern drive position while trailering? pincourtmariah Trailering and Tow Vehicles 8 07-31-2010 10:09 PM
    Key stuck in start position Holy Crap Billyclub Original Mariah Talk 2 07-27-2009 04:10 PM
    There are 301 users
