New Member
Introductions
Old 10-13-2018, 05:21 PM   #1
Hick775 is currently offline
My Model: z252 Shabah
Send Hick775:
Default New Member
Hello,
I have a 1999 Shabah Z252, 7.4 Bravo 3. I have a question right out of the slip. I keep getting water in the ski locker and I cant figure out where the heck its coming from. I inspected the whole area in the rear of the boat by the bilge/engine compartment while coved out and I dont see any water leaking in around the transom assembly. When I put her on the lift after we are done for the weekend I always vac out the excess water in the bilge and ski locker. (super anal about boat being wet inside while not in use) When I vac out the ski locker i put the vac hose directly on the drain tube hole and suck about a gallon of water out after a full weekend on the water. I know there is a sub floor under the bilge floor directly under the engine that leads to the drain plug in the rear of the boat so I'm assuming that the water is collecting there. Any idea where the water is coming from?
Thank You,
Hick
    Total Members: 18,990
    Total Threads: 13,324
    There are 184 users
