-   -   95 Z202 new owners....need info (http://www.mariahownersclub.com/forum/introductions/11762-95-z202-new-owners-need-info.html)
Dkim shabah 08-31-2017 12:46 AM
We just recently purchased a 95 Z202 and other than the obvious "loving it" comment, we have not been able to completely figure out the instrument panel. Although it was a one owner boat, we purchased it from the daughter and her dad apparently did not let anyone else drive or even touch the switches so she was clueless except for turning on, the battery disconnect and bimini top.
Any info you may have as to what the various switches mean (some obvious, some not too much) and where the fuse panel is as a few switches are not working. We have found the "reset" panel for 12 or so switches that seems to work like a GFI, however do not know where the main panel of actual fuses may be located and that seems to be best place to start.
Thank you in advance for any help you can provide. We know we will enjoy taking any advice from current owners as this boat is very different from any of our previous ones.
Take care - Kim and Dave
tbrookens 08-31-2017 01:37 PM
Re: 95 Z202 new owners....need info
Welcome to the group! On both of my Mariahs, the fuses are tucked away under the dash. You'll have to get down on the floor and look up. As far as the switches, if you can post a picture, we can tell you what their functions are.
pllevine 09-02-2017 01:23 AM
I know that you have a "Z" model 202..... Does your dash look like this:
https://uploads.tapatalk-cdn.com/201...6f38090635.jpg
If so, I can probably tell you where to find the engine compartment blower switch, the running lights switch, and most of the dash Carling switches. I added a few extra switches, like the VHF radio switch and the Docking Lights switch (I had to add mine and Z models come with the lights)....
