New Owner
Hi everyone. I am the proud owner of a 2001 Z302. I'll probably have lots of questions in the next few weeks as I get familiar with the boat.
Re: New Owner
Congrats! I'm also a newer owner of a 1999 z302, had it a few months now and been working on it non-stop and getting pretty familiar with it. Let me know if you have any questions and I'll try and help. My z302 only has 454mag mpi with bravo 1. Max speed 50. Wish mine had the 496 in it.
I was already somewhat familiar with it, my father bought one new in 2001 and owned it for 9 years before selling it to old member "Firth's Impression". |
Re: New Owner
Hola, I have a 99. I have done some work on it but by no means a pro. If you have questions or suggestions we are all ears...
Re: New Owner
Re: New Owner
Thanks guys! I've owned a saltwater dual outboard before so a lot of this boat is new to me. I was able to take her out 3 times before it got too cold. The only issue I have is there is a little belt squeal happening at a certain RPM range. Any ideas on how to fix that? I also have the 454 but with the Bravo 3.
No other issues at the moment but I'm sure I'll have some questions when I get her back on the water next year. |
Re: New Owner
Welcome. As for the belt, probably needs tightening unless it's a serpentine belt. If serpentine, then look at the belt tensioner (if it has one) to see if it still has the spring to it. One thing that has often worked for me, car or boat, is to take off the belt and flip it. Sometimes that makes them quiet again.
Re: New Owner
Re: New Owner
Hi, I had a squeal from my serpentine belt and a couple of short sprays of WD40 anywhere on the inside of the belt stopped it. Good luck Sent from my iPhone using Tapatalk |
Re: New Owner
Is the belt squealing or just letting out a chirp or squeak in a rhythmic fashion. If it is squealing then it is slipping on something which is not good, check each accesory and particularly your raw water pump. Its possible that a bearing is about to lock up. If it is just a chirp I have found that rust builds up on the various pulleys, particularly the smooth water circulator pump pulley where the back of the serp belt rides and causes a chirp or squeak. Sanding down and repainting the offending pulley face cured my 7.4 MPI.
Re: New Owner
I have a 2001 z302 also and have done quite a bit of work,, Congrats!!!
| All times are GMT. The time now is 05:29 PM. |
