2001 192 shabah. New Member
We have just got the above boat which runs beautifully with her 4.3l mercruiser.
I have a couple of issues I want to resolve: The tacho is not working, is this likely to be the gauge or a connection somewhere? The fuel gauge is not working, is this likely to be the gauge or sender? How might I test? Is there an easy way to remove gauges from dash, it is really tight to get in behind them? Thank you in advance for any help on these issues. Andrew |
Re: 2001 192 shabah. New Member
I thought I would add a pic of her.
Unfortunately there is not. I have a 95 Barchetta and replaced all the old gauges with new Faria gauges. Coming from the starboard headrest the middle gauges went in pretty easily. The outer gauges were a bear. I bought a cheap set of open end wrenches and cut them in half. I was able to get to each side and install all the gauges. It still was tedious but it worked.
| All times are GMT. The time now is 04:37 PM. |
