just bought a1995 mariah barchetta
I just bought a 1995 Mariah barchetta. I have electrical problems. The blower not working . the bilge pump not working. I have no running lights. when I turn on the switches no light comes o .the two Acc switches work fine.
Re: just bought a1995 mariah barchetta
I have a 95 Barchetta also. The running lights are on the left side just below the ignition. Make
sure the switch is strait up. Then switch it to the left, it should go on. Two turns to the right turns mine off. As for the panel where the blower is, I replaced the fuse box with a Blue Sea Systems fuse block and installed new connections. Everything worked after that. It is an easy boat to work on. Sent from my iPhone using Tapatalk |
| All times are GMT. The time now is 12:41 PM. |
