hi every one
Introductions
Old 06-06-2017, 05:39 PM   #1
hatuly is currently offline
My Year: 2005
My Model: Glastron
My Engine: Alpha 4.3
Send hatuly:
Default hi every one
I am new member and not so good with website , question to anyone can help, after I unscrewed all screws from plate that hold throttle handle, I cannot separate the handle from the control box in the back, I tried to shack it I tried to pry it but it wont separate, any advise thanks my model is Quicksilver 3000 cerise
  • Old 06-08-2017, 05:44 AM   #2
    My Year: 2005
    My Model: Glastron
    Send hatuly:
    Default Re: hi every one
    problem solved I was able to unscrew throttle handle, thanks to you all.
    Old 06-08-2017, 12:32 PM   #3
    My Model: Z202
    Send Firestone:
    Never taken mine apart, so could not help. What was the issue with it not coming apart? What are you doing to it?
    John
    Old 06-08-2017, 05:59 PM   #4
    My Year: 2005
    My Model: Glastron
    Send hatuly:
    I was trying to part between handle and control box did not happen then I puled push button of neutral position and saw a screw with hole in middle unscrew it and problem solved thanks for your att..
    There are 314 users
