Mariah 182 depth finder
Introductions
Old 07-17-2016, 04:24 PM   #1
Tinman is currently offline
My Model: 182
My Engine: 4.3l
Send Tinman:
Default Mariah 182 depth finder
Ok, I have read a few posts about the depth finders, but none are like my issue... It has power, the puck is still glued good under the motor, but just flashes .5 when I turn it on... Any ideas??
  • Old 07-19-2016, 05:23 AM   #2
    My Model: Z202
    Send Firestone:
    Default Re: Mariah 182 depth finder
    Mine does that 50% of the time. Have not had time to chase it down.
    Firestone - 2000 Mariah Z202 5.7L MAG Alpha I Gen II
    John
    Old 07-19-2016, 10:58 AM   #3
    My Model: 182
    My Engine: 4.3l
    Send Tinman:
    I guess the real question after reading more posts about this, what is the correct way to get the puck off the bottom of the boat? Mine is in a hole down below the engine. I feel like prying it out with a screw driver is a horrible idea... If it just needs to be re epoxied, what do I use to get the old off?
    Old 07-27-2016, 03:56 PM   #4
    pllevine's Avatar
    pllevine is currently offline
    My Model: 202 Shabah
    My Engine: 5.0L Alpha
    Send pllevine:
    Like I said in my post, I used a short crow bar and a small sledge hammer. I gave it a hit at the bottom and it came right out.... Intact... But at that point, I would just replace it.
    1998 202 Shabah 5.0L Alpha 1
    Phil Levine
    1998 202 Shabah
    Depth Finder diablo18 Original Mariah Talk 14 05-28-2013 02:15 PM
    Depth Finder jchestnutt Introductions 1 05-06-2012 12:16 AM
    Depth Finder Problem?? hatran Introductions 2 05-20-2010 06:18 PM
    Depth finder joeboat Original Mariah Talk 1 08-21-2009 12:54 AM
    There are 259 users
