-   -   Trim and tilt (http://www.mariahownersclub.com/forum/introductions/10512-trim-tilt.html)
Wade 09-19-2015 03:36 AM
Trim and tilt
Does anyone have a break down of a wiring section for a trim and tilt on a 1998 4.3LX Mercruiser
need to make sure wiring is in the correct spots
mikeyt 09-19-2015 04:56 PM
Re: Trim and tilt
There are number of STICKYS to be used as trouble shooting guides located in the General Maintenance section.
Wade 09-20-2015 02:07 AM
Re: Trim and tilt
Thanks mikeyt
Wade 09-20-2015 02:14 AM
Re: Trim and tilt
Fuel pump on a 4.3 l mercruiser 1998
I started noticing when im trying to start my boat that the fuel pump isnt giving a puff of gas in the carb.
But when I took the line off my carb and turned the engine over there was nothing but in a short bit when I tried again a shot of gas came thru the line,does this mean my electric fuel pump is going(my pump style is long like a cylinder style and mounted on the front of the motor.
mikeyt 09-20-2015 02:53 AM
Re: Trim and tilt
Probably yes the fuel pump is failing. You can either rebuild or replace. I would replace.
