Hello Everyone!
Introductions
Old 06-24-2015, 07:34 PM   #11
94z190talari's Avatar
94z190talari is currently offline
My Model: Z190 Talari
My Engine: 4.3LX
Gallery Images: 12
Send 94z190talari:
Default Re: Hello Everyone!
Easy fix is math. Subtract 10 if you know it's off by that much. I'm sure where the sensors are causes some of the variables. Reading right on top of water is going to be higher than below surface. Same with air temp sensor. It's probably picking up extra radiant heat from boat hull. Not sure where the sensors are but ballpark idea is about as good as it gets.
  • Old 06-24-2015, 08:01 PM   #12
    iced98lx is currently offline
    My Model: Z200 Shabah LE
    My Engine: 5.7L Alpha
    Send iced98lx:
    Grabbed an accurate water temp sensor and compared, it actually fluctuates too much to have a constant correction factor. Sort of a bummer.
    Old 04-19-2016, 10:12 PM   #13
    Send iced98lx:
    An update for this spring! Boat ran great last summer, getting ready for this spring picking up a 3600lb lift with canopy so it's always at the ready as well as a set of smart tabs (on their way now). Really looking forward to getting even more time in on the water with the boat just a few cranks away.
    Old 04-20-2016, 07:42 PM   #14
    Bad habit is currently offline
    My Engine: 4.3 mercruiser lx
    Send Bad habit:
    Welcome
    Nice boat 👍🏻
    Old 04-22-2016, 03:01 AM   #15
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    I'm officially jealous...
    Old 06-06-2016, 02:39 AM   #16
    Send iced98lx:
    Got the boat in the water and on the lift. Still to do: install trim tabs and decide on new prop. Also need to fix the panel the throttle is on, seems the screws have all stripped out.
    Sent from my XT1575 using Tapatalk
    Old 06-06-2016, 02:48 AM   #17
    Send iced98lx:
    Old 06-06-2016, 03:26 AM   #18
    My Model: Z202
    Send Firestone:
    Wow nice set up all the way around!
    John
    Old 06-06-2016, 05:53 PM   #19
    dafucwuzat is currently offline
    My Model: talari 221
    My Engine: merc 5.7 b3
    Send dafucwuzat:
    +1 on firestones reply. I like
    Old 06-07-2016, 01:36 PM   #20
    Send iced98lx:
    Thanks guys! It's got very low hours on it (115 or so) so we'll be aiming to increase that this summer now that it's just a crank or two from the water!
    There are 219 users
