Hello From Melbourne Beach
Hello Fellow Mariah owners!
New to the forum. Have a 2006 Mariah 212 DX with outboard. Have a question about the fresh water pump. Boat has two sinks and a rear shower. Water is filled with external port on the hull on starboard side. Gauge shows about 5-6 gallons on-board, turn the switch and I hear the electrical pump running, but no water ever comes out of the sinks or rear shower. Cant seem to locate the pump or tank due to small access spaces. Can anyone offer any advice on what's wrong? What to check? I'm a pretty good home OB marine mechanic, even went to school for it, so I'm pretty able and willing to tackle the job, just can't seem to figure out how to get to the pump or tank. Thanks -Mike from Melbourne Beach |
Re: Hello From Melbourne Beach
Hello,
I am having same problem fresh water pump is faulty but can't locate water pump I looked behind capt chair on round opening can see water lines but no pump. Have you been able to find location and pass it on to me ? |
Yes, pump is accessed from rear of boat. Look through round hole, then on starboard side, small electric pump is mounted (screwed) to wood frame. Hard to get to, you need small hands.
Hello from Mims ,Fla
Thank you for reply found the pump it is a Flo jet pump in there and yes it is hard to get to. |
| All times are GMT. The time now is 12:48 AM. |
