Hummingbird Depth Sounder
General Maintenance
Old 05-29-2014, 01:10 AM   #1
nosbonsing is currently offline
My Year: 1990
My Model: 1850xl
My Engine: 4.3 Bravo 1
Send nosbonsing:
Default Hummingbird Depth Sounder
Hey all,
I have a "vintage" Mariah 1850 and it has a Hummingbird sounder in the dash. It seems to be unreliable and shows random readings.
My question is, and I know this is a shot in the dark, but does anyone have a good idea if this is more likely an issue with the electronics or the transducer? If its an electronics issue, do you think I could put a newer Hummingbird sounder on the existing transducer?
  • Old 05-29-2014, 01:20 AM   #2
    Default Re: Hummingbird Depth Sounder
    I'm not a big 'fishfinder' guy but i suspect you wont be able to install a new unit on the existing 20 yr old transducer. First thing i would check is to see that the transducer is still firmly seated in the hull. The epoxy used to seat them becomes brittle after a while and once they begin to work loose they give erratic readings.
    nosbonsing (06-03-2014)
    Old 05-30-2014, 05:34 PM   #3
    Mikey's right. Check the transducer. If it's broken loose from the epoxy, most of the time you can re-epoxy it back down with slow cure epoxy (not the 5 minute fast cure stuff). Just make sure and turn it as you install to avoid any bubbles forming. There's some more specific instructions here on the site, just search epoxy and transducer.
    Otherwise, one of the most common problems with boat electronics like sounders, depth gauges, gps, etc is that they change the fittings every few years, so chances are, a new sounder/gauge will likely not fit your existing plug. If you're having doubts, you could always buy a newer unit with a transom transducer, and just use that! Just make sure and use some heavy duty sealant in the screw holes under the waterline. (3M 5200/4200)
    Old 06-03-2014, 12:11 PM   #4
    My Year: 1990
    My Model: 1850xl
    Send nosbonsing:
    Thanks everyone. Appreciate the ideas.
    hummingbird , sounder
    Faria Depth Sounder Gauge Brewfixer Original Mariah Talk 0 05-16-2012 02:43 AM
    Depth Sounder, funny! moondance100 Original Mariah Talk 13 05-22-2008 02:12 PM
    Broken Depth Sounder Mariah Z276 Original Mariah Talk 0 05-13-2008 11:24 PM
    depth sounder? dieselwiezil Original Mariah Talk 7 04-25-2008 07:51 PM
    Depth Sounder too! moondance100 Original Mariah Talk 3 04-24-2008 07:19 AM
    There are 305 users
