Trailer master cylinder needed
General Maintenance
Old 05-11-2014, 03:03 AM   #1
procraneop is currently offline
My Model: Z215 Talari
My Engine: 383 Stroker
Send procraneop:
Default Trailer master cylinder needed
I have a z215 96 Talari trailer and my master cylinder is shot. Where would I get one?
Thanks in advance
Sent from my SCH-I545 using Tapatalk
Allan Ulsby
  • Old 05-11-2014, 03:55 AM   #2
    Default Re: Trailer master cylinder needed
    Just about any trailer parts store.
    Here is one place
    Hydraulic Surge Trailer Brake Actuators at Trailer Parts Superstore
    Old 05-11-2014, 07:07 AM   #3
    Send procraneop:
    Thanks Larry
    So you replace the while works?!! And not just the master...ok
    I will need to tear into it...thanks again
    Al
    Allan Ulsby
    Old 05-11-2014, 02:13 PM   #4
    That's the easiest and safest way to get it back to working condition Al.
    Just measure the size of the tongue main beam on your trailer , and order or pickup the size coupler that fits.
    Can you give us a pic of your existing mount?
    Old 05-11-2014, 05:00 PM   #5
    Send procraneop:
    Here is a photo of the neck..
    Allan Ulsby
    Old 05-11-2014, 05:08 PM   #6
    Do you have drum or disc brakes Al?
    Old 05-11-2014, 07:30 PM   #7
    Send procraneop:
    Drum....those pins are a biatch to get out...especially the front one
    Allan Ulsby
    Old 05-11-2014, 08:42 PM   #8
    Did you get it off?
    Use a die grinder , or maybe a dremel if you have too.
    Then you can get one like the #70463 in link I gave you , or similar style.
    Old 05-11-2014, 09:23 PM   #9
    Send procraneop:
    Yeah ...got it off. So now I have basically 2 parts...the hitch and master cylinder..
    I wonder if I should convert it to electric brakes? If it can be done then I would have to worry about leaks again...
    Allan Ulsby
    Old 05-11-2014, 09:35 PM   #10
    Electric brakes and water don't get along real well Al , but if your in a freshwater area all the time , I would think they would be fine.
    Some of the other members with trailer brakes can give you a better opinion on them. My little Diablo trailer has none.
    Brake Master Cylinder Removal cookscc Trailering and Tow Vehicles 7 05-30-2024 06:45 PM
    Trailer question asap input needed Thanks! gahooligan Original Mariah Talk 25 07-15-2013 04:44 AM
    Master cyl, for boat trailer karmann Trailering and Tow Vehicles 4 10-08-2011 01:08 AM
    Master cylinder on surge brake Repair/Replace? Z 202 Trailering and Tow Vehicles 6 09-09-2008 03:56 AM
    Master Cylinder for breaks turfguy99 Trailering and Tow Vehicles 1 07-29-2008 08:12 PM
    There are 373 users
