Re: Alarm when key in accessory position
My 2001 Diablo with the 3.0L operates like a car as well. Movement is clockwise as follows OFF-ACC-ON. I believe mine is all original, as the key has the correct cut/letter code. Also, mine came with the stock radio and unmodified wiring - it was setup to either turn on the radio via the accessory switch (no key) or ignition switch (with key). Again, my wiring was never cut or spliced. If it was modified someone took the time to run the wires inside the master loom. No other items ran on the accessory until I added my lowrance lst-3800. Also, mine has never beeped or let out any type of alarm noise since I purchased it. I'm not even sure where the noise maker is located.... unless it played through the original radio which I replaced before every taking it on the water.
Nick Sent from my SCH-I535 using Tapatalk 4 Beta |
Accessory switch? What / where is that? Mine sounds like yours, except there is a loud alarm whenever in the ACC position. I don't know what the original radio was, I replaced a tape deck with a CD player when I bought it but I was able to reuse the existing wiring. The tape deck had the same issues. |
| All times are GMT. The time now is 05:41 PM. |
