getting shocked with key
General Maintenance
Old 05-30-2013, 05:18 PM   #1
Medic35 is currently offline
My Model: Shabah 198
My Engine: 4.3 L V6
Send Medic35:
Default getting shocked with key
Hi, I'm new to the forum. I have a 1997 shabah 198. I'm getting shocked when I turn the key. I was planning on running a new ground from the battery to the switch but I'm not sure which wire is the ground and I don't have a volt meter. Red and black wires are going to the same terminal, which I'm assuming is the problem, but the previous owner did some "spectacular" electrical work and I'm afraid to start repairing his mistakes. Does anyone know of a wiring schematic for the ignition switch?
  • Old 05-31-2013, 02:30 AM   #2
    Default Re: getting shocked with key
    First off welcome!
    Ok.....if you have a black wire running to the switch your in trouble unless someone spliced into a wire.
    Here's what you should be looking for:
    Red/Purple Wire = B Post On Switch
    Purple Wire = I Post On Switch
    Yellow/Red = S Post On Switch
    Hope that's what your after. This is from Mercs 4.3 manual but should be identical for all engine combos
    There are 314 users
