Re: LED Docking lights for your Mariah
O WOW! They look great! A lot better then I pictured they would look. Thanks for the pic with them installed. Think im going to have to get me some of those I really like them. Thanks alot for the info
Those do look good. One thing I'd be interested in is LED replacements for existing docking lights.
Also is there any way to adjust the docking lights? Mine are all screwed up. |
I think the only thing that can be done is to get a different bulb throw pattern, either a spot or a flood. As far as LED replacement bulbs, I haven't found one yet, but I'd consider it if they were able to put out a comparable amount of light.
Hmm. The weird thing is one shines about 10 feet infront and the other about 3 feet.
I have the stock stainless steel docking lights in the bow. They look great but are intended only for docking. One year on the fourth of July I got pulled over and cited with a warning for having the docking lights on while underway. Something to do with their location in relation to the bow running light. They said you couldn't see the bow running lights and therefore was illegal to use them while underway. I did get off with a safety inspection and verbal warning.
My Shabah came with docking lights but now one of them is blown. Anyone know where a replacement can be found?
Captain Rod,
I found a place online that sells them. I recall that they were fairly cheap but you had to solder on the original leads from your old bulb. Let me dig up the info. |
| All times are GMT. The time now is 08:08 PM. |
