93 MX20 Steering Problem
Have a 1993 Mariah MX20 with a 4.3LX Merc. Went to put her up and the steering is very hard, my son told me the steering was intermittently ok then bacame hard to steer. I pulled the cable pin and turned the wheel and it seems not as easy as I would have expected but it is not as hard to turn as when running and on the water.
I looked over the cylinder and it is wet with fluid. I assume I need a rebuild kit but the only numbers I can find on the steering unit is 02013401. Does anyone have any ideas on who made this unit and or what rebuild kit that would fix this problem. Thanks, OhmyMariah |
Re: 93 MX20 Steering Problem
Here is a diagram , but it looks as though the rebuild kit is obsolete from Mercruiser.
http://www.boats.net/parts/search/Me...nts/parts.html I would do a web search for Mercruiser part #25- 58224A 1. You might luck out. Otherwise look in Ebay , I see the whole cylinder on there a lot for sale. Larry |
Larry,
Thanks for the reply looks like I am in trouble with this. I think my only choice is to take it out and try to mach up the o rings. I really don't have a $1k to spend on a new steering cylinder. Mark |
Ebay=
Mercruiser Hyd Steering Cylinder | eBay Mercruiser Power Steering Actuator Alpha I Gen II 0 201 340 1 170792 | eBay Search: mercruiser alpha 1 steering That's just a couple. Buy ya one and save the headache :) BTW: Welcome to MOC!! :) Larry |
Jumping in with another link for everyone.
http://www.surpluscenter.com They have a ton of hydraulic stuff and a lot of NOS parts they've bought from companies. I built a log splitter and bought everything from them but the steel. Sent from my SCH-I535 using Xparent ICS Tapatalk 2 |
| All times are GMT. The time now is 09:00 PM. |
