Anyone know where these go?
General Maintenance
Old 07-11-2012, 02:03 AM   #1
jchemotti is currently offline
My Model: 180SE Shabah
My Engine: 3.0 LX
Gallery Images: 1
Send jchemotti:
Default Anyone know where these go?
I have found at least 7 of these aluminum backplates, mostly in the sidepockets of the hull...I'm thinking they might be anchors to secure the dash...??? which is sounding pretty rattly...
Jan
1997 Shabah 180SE
3.0 LX - Alpha
A perfect mix ~ my dog, a book, my boat.
  • Old 07-11-2012, 02:06 AM   #2
    Default Re: Anyone know where these go?
    That's what they are. Reinstalling them can be a real pita too cuz they are difficult to reach & if you overtighten you will crack the dash attachment points.......which kinda sounds like what has already happened... :-(
    jchemotti (07-12-2012)
    Old 07-11-2012, 02:17 AM   #3
    My Engine: 3.0 LX
    Gallery Images: 1
    Send jchemotti:
    Thanks Mikey, I can always count on you to know what's going on...so, it occured to me that I'd have to get under the dash, but what's the key to doing a good job? And, do I look for pre-drilled holes in the underside of the dash form, or do they connect to something else?
    As in most of life, pita seems to be the operating mode...
    Jan
    1997 Shabah 180SE
    3.0 LX - Alpha
    Old 07-11-2012, 02:50 AM   #4
    hi Jan,
    I did this job back when i bought my boat in 2006 so my memory is a bit fuzzy (other than the pita part) of what exactly i had to do. I seem to remember finding those little plates & then reaching up underneath my dash & feeling the attachment bolts hanging loose. I can't remember whether or not i was able to see what i was doing but since i'm working on my boat tomorrow (trying to fix the trim motor) i'll have a look & let you know what i find.
    Old 07-11-2012, 06:58 PM   #5
    hi Jan,
    Had a look and took a couple of photos on the passenger side up behind the glove box. There is a captive nut inside the hole in the pic where a bolt or stud would go and then the backing plate & a nut. Now that i've seen it again, i didn't reinstall those backing plates. Instead i loosed off the dash and installed some rubber stripping to get rid of the rattle.
    Old 07-11-2012, 07:05 PM   #6
    My Engine: 3.0 LX
    Gallery Images: 1
    Send jchemotti:
    Ahhh...thanks for the information...this looks like a maximum pita effort, but I'll give it a shot...did you get the rubber stripping from a weatherstripping section in the store?
    Jan
    1997 Shabah 180SE
    3.0 LX - Alpha
    Old 07-11-2012, 07:29 PM   #7
    Yep.
    Old 07-12-2012, 09:46 PM   #8
    hi Jan,
    I just remembered this thread by Klattu that shows how those backing bars are installed.
    There are 329 users
