Bilge clean
General Maintenance
Old 05-29-2012, 04:49 PM   #1
Oregondunes's Avatar
My Model: Z302 Bow Rider
My Engine: 7.4 bravo3
Gallery Images: 36
Send Oregondunes:
Default Bilge clean
Yikes. After the last ride I pulled the plug and out came some crap I dont know where originated.
So i sprayed the hose up into the drain several times until the water started to come out clean. I then shot a bunch of simple green around the motor (sprayed it down with the hose) and back up the drain and took it for a ride.
Much better.
2000 Z302 Bow Rider
  • Old 05-30-2012, 03:05 AM   #2
    rayzorback's Avatar
    My Model: 210 LE
    My Engine: 454 Bravo 1
    Gallery Images: 10
    Send rayzorback:
    Default Re: Bilge clean
    Pouring a little "Simple Green" in the bilge and a little water, then go out on the water for the day and when you return to the dock and trailer the boat, then you pull the plug to drain the water, the bilge should be really clean. It works for me.
    Old 05-30-2012, 05:08 PM   #3
    Gallery Images: 36
    Send Oregondunes:
    i did and that worked its magic for sure.
    2000 Z302 Bow Rider
    1996 Mariah Shabah Z252 (SUPER CLEAN) stuartm77 Mariah Boats For Sale & Wanted 1 05-09-2012 05:26 PM
    keeping boat clean and protected..whats the best products..? lcoen777 General Maintenance 13 07-01-2009 03:16 PM
    Clean and paint an Alpa One outdrive sirbb General Maintenance 4 05-09-2009 03:31 PM
    Clean way to charge batts when shore power is avail. Jeff Barnett Boating 101 0 09-17-2007 09:31 PM
    There are 353 users
