electrical?
General Maintenance
Old 05-26-2012, 02:06 AM   #11
DougR is currently offline
My Year: 2003
My Model: SX 20
My Engine: 5.7
Send DougR:
Default Re: electrical?
Are you sure it's a knock sensor and not the starter relay?.?.?.?
  • Old 05-29-2012, 03:22 PM   #12
    dcgragg's Avatar
    dcgragg is currently offline
    My Year: 96
    My Model: shabah 200
    My Engine: 5.7
    Send dcgragg:
    ran good all weekend. and as rough as the water was it was the perfect test. when i get a day off again i will trace the wire and see what exactly is going on with the breakdown. at least i know it will run. thanks for all the input.
    Old 05-29-2012, 04:21 PM   #13
    dwmax's Avatar
    dwmax is currently offline
    My Model: Shabah 212 Limited
    My Engine: 350 mag with alpha one
    Gallery Images: 17
    Send dwmax:
    just a thought i just went through this on my boat and i found out that if your tachometer is not working you will not get power to your coil.it is very simple to check just disconnect your tach completely and dont let any wires touch of course and then try starting the boat if it starts you will know that your tachometer is bad. just so you know this is one of the test that the mercruiser shop manual tells you to try if you dont have spark.. Good luck and let us know what you find.
    Darrell
    Old 07-08-2012, 06:38 PM   #14
    Ed Degliantoni is currently offline
    Send Ed Degliantoni:
    I have a 1995 202 Telari and the head light switch is broken,will not switch off, Where are there supply's for this?
    Thanks for taking this message,
    Ed
    Old 07-09-2012, 01:47 AM   #15
    dcgragg's Avatar
    My Year: 96
    My Engine: 5.7
    Send dcgragg:
    thanks for all the suggestions..... it wound up being the purple wire coming from the igntion switch. the wire is apparently broken down somewhere between the key and the coil. i ran another wire and i have spent the entire week of the 4th of july on the lake with it and it never missed a lick....
    electrical problem breakaway Original Mariah Talk 3 03-09-2012 07:58 PM
    Electrical issue! Who's the electrical guy? Eddie Original Mariah Talk 9 05-06-2009 04:52 AM
    Electrical Z210Shabah Original Mariah Talk 3 04-05-2009 11:40 PM
    Electrical Fix Straad General Maintenance 2 08-28-2007 12:26 AM
    There are 379 users
