-   -   Closing Windshield (http://www.mariahownersclub.com/forum/general-maintenance/6804-closing-windshield.html)
klattu 05-13-2012 04:58 PM
Closing Windshield
1 Attachment(s)
Anyone have this problem?
Center windshield is too tight when closed, need to hit it to fit in opening.
What did you do to make better?
I put a jack between the walls, and spread them enought to let window close easy, a little more since it will spring back in a few days, I think.
Maybe best to leave it like this all winter next year.
mikeyt 05-13-2012 05:12 PM
Re: Closing Windshield
Take the foam strip out, loosen off the screws, move the windshield a bit, tighten the screws & put the foam back in place.
Wattsjam 06-10-2012 03:09 AM
Which foam strip do you take out. Mine is doing the same thing?
mikeyt 06-10-2012 10:04 PM
The foam strip under the glass on the outside of the boat.
Wattsjam 06-11-2012 01:04 PM
Thanks, I 'll give it a try. New boat to me. I have a few things to fix.
Have you ever had trouble wiht the motorized stern light?
mikeyt 06-11-2012 10:45 PM
Me personally no i haven't but a few others have. Usually its the result of a bad ground. Replacement units are available. Check our Vendors List.
Kitto 06-12-2012 04:50 PM
I had this problem when I first purchased my boat. The center windshield would ride above the opposite side windshield. I removed the black rubber, pulled the screws that attach the windshield to the fiberglass and moved the windshield out on the starboard side. I re-screwed the windshield down and it fits perfectly. I do have a couple of holes visible from the inside, I just haven't chosen to refill them. It really wasn't too bad a job.
Kitto 06-12-2012 05:03 PM
What it looked like before I did the work.
http://i1149.photobucket.com/albums/...to/boat002.jpg
Wattsjam 06-13-2012 05:20 AM
i tried moving the windshield and it worked like a charm. Only took about 20 minutes. It fits perfectly now. Many thanks,
mikeyt 06-13-2012 10:55 PM
:wink_thumbup:
