Dash problems
General Maintenance
Old 05-07-2012, 05:30 PM   #1
Spoonman is currently offline
My Model: 212 BR
My Engine: 5.7 Mag Alpha 1 Gen 2
Send Spoonman:
Default Dash problems
ok, heres the deal. I purchased a new hummingbird depth finder. The existing lowarance always reads .5 ft. The installation instructions seem fairly straight forward but the problem lies in the removal of the old one. The boat is a 2001 Mariah 212 and the dash is all molded fiberglass, you cannot even see the back of the existing finder from underneath. From in the bow you can flip up the starboard back rest and see a little of it, but my bifocals don't really do me justice. Regurdless it seems that there are screws from the front but there is no way I want to pry around on plastic trim on the dash of a boat that the company is no longer around. Does any body have any suggestions?
  • Old 05-08-2012, 12:20 AM   #2
    Default Re: Dash problems
    What Lowrance model do you have?
    Larry
    Old 05-08-2012, 01:33 PM   #3
    My Model: 212 BR
    Send Spoonman:
    I am not sure if the model but it is just the std 2" dash mount.
    Old 05-08-2012, 08:55 PM   #4
    rayzorback's Avatar
    My Model: 210 LE
    My Engine: 454 Bravo 1
    Gallery Images: 10
    Send rayzorback:
    Should be a bracket on the back with a small nut that needs to be removed. Might have to have eyes in your fingers to get at it. I removed my drivers foot kickboard and could get to mine fairly easily.
    Old 05-08-2012, 08:57 PM   #5
    My Model: 212 BR
    Send Spoonman:
    That might give me a better vantage point, will look at that this eve. Thanks
    Old 05-08-2012, 11:29 PM   #6
    Sounds like you have the 3500 series Lowrance sounder.
    There are two phillips screws on the sides in the back that you need to loosen to remove the unit. They are across from each other on the unit. According to the install instructions you might need to pop off the bezel first.
    Hope that helps you out!
    Larry
    Old 05-09-2012, 11:53 AM   #7
    My Model: 212 BR
    Send Spoonman:
    OK, Whats a "BEZEL" ?
    Old 05-09-2012, 12:58 PM   #8
    That is the outside ring with the glass in it.
    I'd try loosening the screws and removing the unit with the bezel on first , sometimes the bezel(ring) will break because of sun/weather exposure.(If your trying to save the unit)
    Larry
    Old 05-09-2012, 01:05 PM   #9
    My Model: 212 BR
    Send Spoonman:
    Sounds good I'll give it a try. Thanks
    Old 05-12-2012, 05:31 PM   #10
    klattu's Avatar
    klattu is currently offline
    My Model: 182 Ghost
    My Engine: V6
    Gallery Images: 33
    Send klattu:
    Keep this for future referance... very important not to mix up
    dash fading or white residue on dash 2009 sx20 wakenbake Sea Fox - Mariah Talk 1 02-24-2011 06:37 PM
    Wanted: I need dash switches 94Z212 Mariah Parts For Sale & Wanted 2 10-06-2009 07:30 PM
    Discolored Dash? Sewlong General Maintenance 8 03-31-2009 01:13 AM
    Dash ice box lid Mach Man Original Mariah Talk 8 01-07-2009 04:12 AM
    dash lights John Miller Original Mariah Talk 3 05-20-2008 02:08 AM
    Total Members: 18,990
    Total Threads: 13,324
    There are 234 users
