Bilge Pump Replacement
I have a 97 Mariah 180 Shabah, with a 4.3L V6. Does anyone know if there is a direct replacement that I can order for my boat.
Re: Bilge Pump Replacement
Not sure of a direct replacement but they are pretty generic and easy to swap out if you can get to the old one.
Just replaced part of mine earlier this year. Mayfair is the OEM manufacturer, which has now being distributed under the name Johnson Pump. I believe it's a 1250GPH pump with an automatic float switch. You can usually just buy the top half of the pump as a replacement, that's one of the nice features of those pumps. That way you don't have to go drilling new holes, etc. I got my stuff from
Wholesale Marine |
I just worked on mine this weekend. Ended up being the switch that went bad. Caused the whole thing including the automatic float to not work.
| All times are GMT. The time now is 01:02 AM. |
