-   -   Boat has sat for 2 years? What to do? (http://www.mariahownersclub.com/forum/general-maintenance/5101-boat-has-sat-2-years-what-do.html)
lmuearl 12-24-2010 05:20 AM
Hello everyone, I have a 1996 Mariah 220 Talari. I went back to school to finish my degree and because of financial reasons had to let the boat sit for 2 years. However, its time to get back out there and I need to know what I need to repair, replace or check up on? I live in Southern California and don't need to winterize it because it does not get below freezing. I have kept it covered and kept the trailer tires filled and covered. Please give me any suggestions on what I should do. Any websites or email me with info. ([email protected]). Thanks again and I'll see you on the water.
mariah bob 01-02-2011 12:19 AM
Re: Boat has sat for 2 years? What to do?
Hopefully you used fuel stabelizer or better yet drained the tank and ran the carb empty. If not, that would be the first thing i would do is drain everything, new filters and fuel, new battery.
mikeyt 01-02-2011 06:08 PM
Yep, all the fluids & filters should be changed. A bit of lubrication for the moving parts (outdrive, steering etc) might be in order too. And as Mariah Bob says, hopefully you used some fuel stablizer 2 yrs ago so that the carb etc isn't gummed up.
Hudson River Steve 01-02-2011 10:47 PM
If you didn't fog the cylinders before laying up, you may want to consider removing each spark plug and squirting some WD-40 or fogging oil into each cylinder. I would use a wrench on the crank bolt to slowly turn the engine over before cranking with the starter...just in case you have a stuck ring. Good luck and welcome back to the water!
